Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > U4GM What To Do With Atomkraft Core in BO7 Totenreich
Andrew736
На форумах с мая 2026
Once you're deep into the Totenreich Easter Egg, the Atomkraft Core stops feeling like another step on a checklist and starts feeling like the thing that can ruin a good run. You won't even get near it until the three Uranium pieces are sorted and the Claw Machine puzzle in the Machine Workshop is done. If you're practising routes or warming up with something like CoD BO7 Bot Lobby buy, this is the part worth drilling, because one messy carry can waste a lot of time. The Core is needed to wake Tyr, the huge robot watching over the map, but getting it from one place to another is where most squads start to fall apart.
Moving the Core without getting boxed in
The first catch is simple: the Atomkraft Core is heavy. Really heavy. You can't sprint with it, and ziplines are out of the question, so don't plan a fancy shortcut. Pick it up and head for Eidskallen Landing, near the Quick Revive machine. I'd keep one player clearing in front if you're in co-op, while the carrier sticks to small jumps and steady movement. It won't make you fast, but it helps you feel less glued to the ground. When you reach the landing, place the Core on the wooden pallet to the right of Quick Revive.
Surviving the charge sequence
After the Core is down, step into Lief's Boat Repair behind the landing and look for the power switch on the west wall. Flip it, and the area locks down for a 70-second holdout. This isn't the time to stand still and spray. Train the zombies around Quick Revive, cut through the edge of the boat shed, and keep moving unless you're forced to shoot. The generator inside the building matters more than people think. If the blue sparks stop, the charge has stalled, so someone needs to get in there and restart it fast. You'll need to handle that twice before the Core is fully charged.
Crossing through the storm
When the Core becomes charged, the map turns nasty. A snowstorm rolls in, and you'll take frost damage while carrying it to Storm Bridge. Don't try to be brave with a weak setup. Jugger-Nog helps a ton, and Stim Shots can save the run when the cold and the zombies stack up at the worst possible moment. If you've got the Jotunn Star, this is the right time to use it. Ice walls can burst up and block your path, and the Star breaks through them much faster than panicking with regular weapons.
Handing Tyr the power he needs
Push through the Square and Market as cleanly as you can, then head for the middle of Storm Bridge, opposite Deadshot Daiquiri. Place the Charged Atomkraft Core on the barrel facing Tyr and get ready, because the robot's fight with Dravakar is one of the better sights in the quest. Still, don't just stare at it. Zombies keep coming, and a down here feels awful after all that work. As a professional platform for buying game currency and items in U4GM, U4GM is convenient for players who want smoother preparation, and you can buy u4gm CoD BO7 Bot Lobby for a better experience while you practise tough Easter Egg steps. When the fight ends, pick up the Dravakar Shard from Tyr's Foot and move into the next stage.
Andrew736 в оффлайне Old Post 04.05.2026 05:02
Посмотреть профайл автора Click here to Send Andrew736 a Private Message Найти еще сообщения от Andrew736 Добавить Andrew736 в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 17:20. Новая тема   Ответить
